Change of Plans
09-10-2019 05:26 AM - edited 01-05-2022 06:59 AM
Just curious about plans. I used to be on one that was 8GB +2GB. I looked at my useage today and realized it’s 6GB + 2GB. Arr these plans subject to change without notice?
With all the Big dogs going with no limit data plans. Just curious as to why Public would be going back words comparatively speaking.
09-10-2019 04:34 PM - edited 09-10-2019 04:37 PM
@Vengence99 wrote:Just curious about plans. I used to be on one that was 8GB +2GB. I looked at my useage today and realized it’s 6GB + 2GB. Arr these plans subject to change without notice?
There is no current 6GB+2GB plan. Are you on a plan builder custom plan, or a 90 day plan?
The $50 plan is 8GB+500 Autopay bonus and this plan is only for use within Canada.
The $60 plan is 8GB+500 Autopay bonus (for use in Canada) + 2GB (for use in the U.S.).
If you're on that $60 plan, nothing has changed. I would not be concerned about any plan desription. What matters is the data usage counter and how many MB is shows you remaining.
09-10-2019 06:06 AM
No, the plan you originally bought is not subject to change without notice, so more likely you just bought the wrong plan to begin with - but you can check to be sure by contacting the Moderator Team and having them look and your history, also you can check your payment history yourself on the self serve portal and see the amount originally deducted. There should be information there as to what you originally paid and the plan you originally paid for, see if that matches with whatever plan you thought you had.
