Change number
Sweet-33
Hi i would like to change my. Number from. Grande prairie alberta to a peace river alber
dabr
@Sweet-33    Log into your self serve account and on the right hand side of the overview page, select the Change SIM, then Change Number under Quick Link.
PM doesn't offer numbers from every city, but you can select your province and then select Peace River (if available) or the nearest city in that region.  There's an option to refresh the list from the 3 available numbers.
@Sweet-33
Login to My Account, click on Profile , click Change Phone Number
there you can pick the province and city you want to change and select the number from there:
https://selfserve.publicmobile.ca/en/account/edit/your-accounthttps://selfserve.publicmobile.ca/en/account/edit/your-account
Timer
@Sweet-33
You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account here and:
  • Select the “Plans and Add ons” tab
  • Click on “Change Phone Number”
  • Then, you can choose to select a new phone number
