04-10-2021 04:21 PM - edited 01-06-2022 01:44 AM
Can anyone tell me when the data plan changes take effect? I read they were supposed to all change on April 9th but I don't see the increase yet. The $50 plan is supposed to increase to 10gb.
04-10-2021 05:56 PM
Feel like you would have to change plan just like how you have to change plan to get from the previously provincial plans to the canada-wide plans. Best way to save money is to renew at the next payment so that the current cost you paid does not go to waste.
04-10-2021 04:43 PM - edited 04-10-2021 04:44 PM
Login to self serve and view your Plan Details to confirm your current plan data allotment.
Click on the Change Plan tab:
Then select this:
Then select this to "Change on next renewal date"
Now you're all done and will get the changed plan on your next renewal.
04-10-2021 04:30 PM - edited 04-10-2021 05:35 PM
@peewee65 wrote:Can anyone tell me when the data plan changes take effect? I read they were supposed to all change on April 9th but I don't see the increase yet. The $50 plan is supposed to increase to 10gb.
Nothing changes for existing customers unless a plan change is requested. The $50/8.5 and $50/10.5GB offerings are different plans. You'll need switch to the new plan. Current customers do not automatically benefit from the new plans.
04-10-2021 04:26 PM
@peewee65 :You can also check the announcements section of this forum too.
04-10-2021 04:25 PM
Go into your Self Serve account and see if it is available in your "Change Plan" option.
Then if so, set it to "change on next renewal".
04-10-2021 04:24 PM - edited 04-10-2021 04:25 PM
@peewee65...
top of this page, click Plans to see plans as they are today.
04-10-2021 04:24 PM
The changes were effective April 9th.
@peewee65 Edit: The changes are in effect right now, log into your account and you will see the current pricing plus features. Here is a link to the current plans that PM offers with improvements for $35 and $50 plans.
