Change account plan
jnpubl1c
If I downgrade my plan, will I still receive my rewards, referrals, Auto pay and Loyalty credit?
Halazakeya123-
yes U can
HI @jnpubl1c   you will be on your old rewards and still getting all the rewards
The only one that people might loss is the  bonus from activation.  If you don't have those, no need to worry
@jnpubl1c @Your rewards are tied to your account , not your plan
@jnpubl1c @Yes you will be able to keep your rewards
