Change Plan, Keep Rewards?
haze101
Hello,
I am interested in switching my plan from the 3 month $120 plan to the 1 month 15gb $40 offer in my account.
I have $12/month in discounts in rewards applied to my account. Will they stay on my account if I switch plans? Or will they disappear with the old plan once I change? Let me know. Thank you.
porcupine
yes they would stay
HALIMACS
They will remain, @haze101 , just at 1/3 the value as you'll be reducing from 90 to 30 days.
Just make CERTAIN not to be tricked into switching over to the new Public Points system during the plan change and be sure to make the plan change effective on your next cycle renewal, as opposed to immediate, as there is no pro-rating around here.
britmay2
Your rewards will stay 🙂
@haze101  changing plan would have no effect on your rewards, you will keep them as is
Quigley
@haze101
With your plan change, your rewards will stay the same.
Rewards are attached to your account and not your plan.
