07-04-2019 09:02 AM - edited 01-05-2022 05:43 AM
Hi all,
So I went to change over my old number from Koodo (during registration it said to wait), and now when I went to change it, I was told to contact the community. So here I am :). Thanks to whoever is able to do something
Joining Public
07-04-2019 10:02 AM
You must be porting a Koodo prepaid number to PM. PM and Koodo prepaid are using the same back-end. Therefore, the automated number porting system is treating the PM and Koodo prepaid as the same provider since they are sharing a back-end. This is the reason why the "Check eligibility" was giving you the error message "we are unable to transfer your number".
You can get a number from PM during activation. After activation, send a private message to moderator to port your Koodo prepaid number.
Moderator wait time is 2 - 3 days.
07-04-2019 09:35 AM
@jharms wrote:Hi all,
@jharms You need to send PM your Koodo account number, name on the account and your Koodo phone number so that they can submit the port for you.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
07-04-2019 09:24 AM
if your Koodo account is prepaid, you will need moderator help fo complete the porting. Expect 1-2 day wait. Either continue to use your old Koodo SIM card (if working) or activate with temporary new PM phone number.
Send a private message to moderator through the following link :
07-04-2019 09:05 AM
pre or post paid?
Did you complete the activation and port (on self serve side) ?
