Change Email
emkershaw
Hello,
I'm trying to change my email.
HALIMACS
@emkershaw
Once you've taken the advice of the process for changing either the self-serve or the community e-mail, remember that these should match each other so any community effort you may put in to helping others gets credited to your applicable service account.
The matching e-mails are the only way one 'communicates' with the other in regard of community rewards earned and credited.
@emkershaw wrote:
Hello,
@emkershaw
For your Self Serve email only Moderators can change that for your. Follow @computergeek541 method to change it.
For your Community email, you can do that yourself under your Avatar, then "My Settings".
LurganIeUk
@emkershaw wrote:
Hello,
Nice to know!!
What email are you referring to?
1. For logging into your account
2. For your community account
3. Or???
Please go to https://widget.telus.tiia.ai/publicmobile/publicmobile.html and then type "change self serve e-mail".
