01-09-2024 06:18 PM
I recently switched from Koodo to Public Mobile.
I've noticed that certain numbers that call me don't cause my phone to ring, they go directly to voice mail. I don't see any missed call on my phone either from these numbers. Co-incidentally, one of these numbers is Telus Support. These numbers were able to call me before when I was on Koodo. I'm not sure what is going on.
I have a strong signal strength where I am with all bars.
01-19-2024 07:55 PM
@Roycar wrote:I recently switched from Koodo to Public Mobile.
Try reinserting your Koodo SIM card (if you're removed it) and check for voice messages. If you were left messages there, those calls are still going to your Koodo service. The reason that some incoming calls work on your Public Mobile service could be because the calls originating from within the Telus Mobility network. Calls originating from other networks could still being going to your old service. Telus technical support could actually be placing the call from outside fo the Telus network especially if it's from a call centre.
01-19-2024 06:57 PM
I'm curious, was this Samsung Note 9 on any other service before like Rogers Bell Telus... and these numbers that called you worked on their service? Or were these numbers able to call you before while you were on PM and all of a sudden it happened?
01-19-2024 06:49 PM
Thank you @Handy1
01-19-2024 06:49 PM
@Chalupa_Batman I have a Samsung Note 9. I thought about a blocked list, but numbers that previously worked, don't work anymore.
01-09-2024 09:28 PM
I have the same problem. I've had it happen at least twice. I even tried calling myself from a lsnd line and it goes straight to voicemail. Crazy thing is that people can't even leave a voice mail because it says my voicemail is full! (But it's not). When I called myself, it's my OLD Fido outgoing message???
01-09-2024 07:00 PM
Thanks. I just upgraded to a Pixel 7a. I do not recall if I ever used the block number feature. I will give it a try if this happens with the 7a.
01-09-2024 06:50 PM
Evening @funpig1
So, with recent updates, at least on iPhone, the block unknown callers seems to be blocking numbers that are legit. I'm sure the GP3a may have a similar feature. I'd suggest trying to disable the blocking option, reboot and then see if those folks can now reach you. Only downfall is you'll get those crap calls again.
01-09-2024 06:27 PM
I occasionally had the same issue on a Pixel 3a.
01-09-2024 06:24 PM
Hey @Roycar just wondering, you have an iPhone by chance?
01-09-2024 06:22 PM - edited 01-09-2024 06:25 PM
@Roycar Sounds like porting didn’t complete . I’ll send you the porting team number private message and they can re trigger the port request for you
