03-06-2023
01:45 PM
03-06-2023
02:22 PM
computergeek541
Woke up and can’t connect to cellular network?! Apple support says it’s not my phone. How do I get an e-sim?!
03-06-2023 02:36 PM
HI @Dadward eSIM won't help you. PM does not support eSIM
do you see the phones not conected to PM network at all or just no voice calls? PM has some voice issue this morning
Try to put your PM sim card in another phone and test
or try to get another sim card, active one, on your phone to test
also, check if your phone is blocked here:
03-06-2023 02:20 PM - edited 03-06-2023 02:22 PM
@Dadward wrote:Calls fail instantly I am unable to check. SIM card worked in a different phone? But does not in my phone?
@Dadward - oh, well if the SIM worked in another phone, then you have a device issue.
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
EDIT,
Turn off VoLTE if you have a VoLTE enabled phone. If that does not work, connect with contact customer service agent for assistance.
Perhaps you are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
03-06-2023 02:16 PM
03-06-2023 01:54 PM - edited 03-06-2023 01:55 PM
PM does not support e-SIM.
Did you try rebooting your phone (turn off, wait a bit, turn on)?
Check your account if it is Active? Bill paid on time?
03-06-2023 01:52 PM - edited 03-06-2023 01:53 PM
@Dadward - Are any services working?
Can you log into My Account and see if your account status is Active? Or is it Suspended?
Or, when you call 611 (or # 1-855-478-2542 or # 1-855-4PUBLIC from another device) to see what the status says.
EDIT, public mobile does not support esims.
