06-18-2022 09:25 PM
06-19-2022 02:47 PM
@craigcole29 wrote:Thank you, waiting for a response now. How would you check if it’s a issue within your area?
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
When you say data is working are you sure this is not through wifi?
Does your account status say Active?
If data is working and calls and texts are working...they trying in another phone (as @hTideGnow already mentioned), then putting it back into your phone may help; this can do something on the backend of the account. This was a fix for some similar symptoms, so worth a shot.
06-18-2022 09:59 PM
06-18-2022 09:57 PM
@craigcole29 better check out if it is a problem within your own area first
But to contact PM , open ticket with them.
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
06-18-2022 09:55 PM
Is there a way to personally contact a service representative?
06-18-2022 09:37 PM
HI @craigcole29 Reseat your SIM and see if it helps
Try changing to 3G only. If after changed to 3G and you don't have any bars, it's a 3G network problem in your area
Try putting your PM SIM in another phone to test if you have a test phone around
06-18-2022 09:35 PM
This just stated today. I’ve been a public mobile customer for several years. This is the first time having trouble.
06-18-2022 09:32 PM
$40 plan
06-18-2022 09:32 PM - edited 06-18-2022 09:32 PM
@craigcole29 Take your sim out reseat and reboot phone also manually switch to 3g in your settings
06-18-2022 09:31 PM
Are you possibly on the old $10 plan?
06-18-2022 09:29 PM
No, it’s the same sim I had for years
06-18-2022 09:29 PM
Is this a new sign up? Or has this just started? Did you change phones? Are you in MB?
06-18-2022 09:27 PM
@craigcole29 Hi did you port a number if so you must leave old sim in your phone to get text to transfer your number answer yes to complete transfer
