05-22-2026 11:33 AM
Am using a Samsung S20 Ultra 5G Mod SM-G988W which wont pass the IMEI test but is set to LTE/WCDMA/GSM network mode, need to know if it will continue working after 3G is shutdown? Thankyou in advance
05-25-2026 10:45 AM
I have an iphone 6, model MQ 3X2CL/A
software 12.5.8
I frequently get "connection error" on my most used app, and "no service" The phone calling works fine, though.
05-22-2026 11:37 AM
Only calling and receiving calls won’t work but you can use data for internet and using your apps.
05-22-2026 11:35 AM - edited 05-22-2026 11:36 AM
it won't be good according to the Public Mobile device checker.
05-22-2026 11:34 AM
The problem is a combination of 3G shutdown and the lack of VoLTE compatibility
While your Samsung Galaxy S20 Ultra has VoLTE, it is NOT compatible with PM's VoLTE network. You can use the IMEI checker on this page to confirm: https://www.publicmobile.ca/en/on/get-help/articles/volte
Since your phone is not compatible with PM's VoLTE, your phone has been using 3G for voice, but is now affected by the 3G Network Shutdown that has just started in Manitoba:
https://www.publicmobile.ca/en/get-help/articles/3g-shutdown
If you’re using a 3G-only device, your phone will stop working after these dates:
Manitoba (Rural): January 12, 2026
Manitoba (Urban : Winnipeg & Brandon): Starting March 31, 2026
National: Starting March 1, 2027
There is really nothing much you can do other than to get a phone that is compatible with PM's VoLTE network.
iPhones 8 or later, Google Pixel 4 or later, Samsung S22/Flip 2/Fold 2/A15/A35/A55 or later, or other major brands of phones released after 2024 and are designed and sold for the Canadian market should work.
If you are unsure whether a particular phone will work, share the model here and we can help
