Cell Coverage
JRC293
We are on the Bruce Peninsula in Stokes Bay and have just noticed recently that our cellular signal strength is much weaker than it used to be. Does anyone know if there have been changes as coverage should be getting better not worse?
Thanks,
Ross
10 REPLIES 10
JRC293
currently switched to HSPA+/UMTS under network technology so will see if that is any better - thanks
JRC293
only choices that come up for Public are 4G LTE and H - Voice/data
JRC293
no setting chnages seem to help at this point - thanks
HI @JRC293
it is on the Network type screen.
which phone you are using?
JRC293
only shows 4G LTE as an option
JRC293
only shows 4g LTE as an option
jor123
Personally I find the 3G/HSPA network has near unusable speeds and latency.
Meow
Force network to 3G (manual setting) and see if you get any improvement.
hairbag1
Manually select 3G to see if that helps.
HI @JRC293   There is ongoing 5G upgrade and it might affect LTE
can you change your phone network type to 3G Only (some phones call it WCDMA only or HSPA only), does it work better?
