Cant verify my identity
gordonyu
I login to my account perfectly fine and my community account perfectly fine. Talk to the chatbot which opens a ticket for me to get an agent. But when i get to the end to verify my account/ details it says invalid account so I cant even get ahold of...
8 REPLIES 8
@gordonyu
Try clearing cache, cookies and go incognito on your browser before login.
gordonyu
Thank you
gordonyu
Thanks
gordonyu
Yes I did use incognito on the browser but not working.
dust2dust
Just verify with the pin option. I just had a turnaround time of 12 minutes to have the freebies added. I use the pin option. I've never had luck with the login option. I think it's broken. But pin works every time.
walker1
@gordonyu
Please try again, but use a different browser in incognito or private mode instead.  Try again.
will13am
@gordonyu , please try again using incognito mode on the browser.
