11-25-2016 06:40 PM - edited 01-04-2022 01:17 PM
08-10-2019 01:33 AM
Almost a year later and this is your first post. Welcome. Have a look at the date in the upper right corner of posts in a thread. This thread you replied to last had activity about 2.5 years ago.
08-10-2019 01:31 AM
only for android phones.
goto google type in this:
public mobile APN MMS settings
follow their instructions to add the proper APN to your phone. this will resolve your inability to receive text photos.
curtis
08-10-2019 01:29 AM
if your phone is an android and you may also be having trouble accessing data when roaming (ie away from WIFI)
Then you may need to reset your MMS APN Settings on your phone.
Which if you are like me this is all foreign but go to google and type in this:
it will give you directions on how to add a new APN setting to your phone.
this new APN setting is needed to use Public Mobile.
TRust me this works but be patient and meticulous about entering in the info accurately.
Best of Luck.
Hopefully this will help someone out. as i see the easy link for this has been buried under other masses of internet chatter.
Curt
Virus-free. www.avast.com |
11-26-2016 02:53 AM - edited 11-26-2016 02:54 AM
I had a similar issue on my android phone. I'm pretty sure data has to be on to be able to send a MMS.
And as one of the users here mentinoed you have to have the correct APN settings.
11-25-2016 07:01 PM
Check this post out.
hope that helps
11-25-2016 06:48 PM
Is your data turned on?
Double check the APN settings.
