3 hours ago
Once I enter my username and password it prompts me to enter the 6 digit code sent to my cell phone. After I enter that code and hit confirm, it brings me right back to the home page of public moble, almost like it’s not loading my profile, any help would be greatly appreciated as I need to update my billing information for automated payments.
41m ago
@Hunter01 , You're best bet is to contact a CS_agent by opening a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
an hour ago
Tried all those options and unfortunately none of them are working.
2 hours ago
I’ll try the incognito, then download the app if that doesn’t work.
Thanks
3 hours ago
@Hunter01, if you are using the PM app try going into your phone's settings:
If Android, go into Apps then look up the PM app and clear cache/data and then try logging back into the PM app. If iPhone, you will need to uninstall the PM app, then restart your phone and then reinstall the app and then login.
Hopefully you should be able to get in at this point and see your account. The other option is through a web browser as was shared by others
3 hours ago
try Incognito mode or try using PM app
3 hours ago
Website has caching issues.
Try to clear cache first, incognito mode or even a different web browser.
Or try the Public mobile app.
