08-06-2018 06:01 PM - edited 01-04-2022 06:40 PM
Hello
Does anyone know a faster way to get ahold of the moderator's? I'm trying to get my phone plan changed after my account expired for some reason but I can not get ahold of them. I've sent a couple message now over the past 2 days but no response. I need my phone working asap for work purposes as I work in the rescue industry and I need to have constant communication in case of emergencies. Can I do anything to speed up this process
08-06-2018 09:39 PM
@Codybranden wrote:Hello
Sorry, but sending a mesaage to the moderators is the only official way. Hopefully, they will be able to help soon.
08-06-2018 06:18 PM
Sorry I know it sucks but you have already contacted the mods so there is not much more you can do but wait they are really busy but will get back to you a soon as they can.
Should be within 48 hours. No need to send multiple messages or it will just slow down the process unless you forgot to include your identity / pin number for verification then sending a second message (Click to send) will speed it up for you as the first response from them will be "who are you? " or "whats your pin?". For more information about contacting a moderator Click Here
