Cant Change Plan
Bainer55
Im trying to switch plans for a cheaper option but evertyime i log in, for weeks now i cant change plan. it just shows up blank it doesnt even show me what my current plan is. Is  anyone else having this problem? is public mobile trying to prevent ppl at this time trying to change plans because everyone is going to a cheaper option because there all at home?
15 REPLIES 15
popping
@popping wrote:
@popping wrote:
@Bainer55
I get the same blank screen on plan change using my trusted Windows 10 Chrome, FireFox and Opera browsers.
I will update this thread when I can get the proper change plan screen.
But you can create a moderator support ticket to assist you.
Update 1:
I tried Firefox and Opera private mode just now.  Both showed me a list of plans which I can select to change.
But Chrome incognito mode does not work.
Update 2:
My Windows 10 Chrome browser is working again without using incognito mode.
popping
@popping wrote:
@Bainer55
Update 1:
gc3
I had this problem a year ago and had to use a different browser. Everything is showing up properly now running Microsoft Edge Version 81.0.416.53 (Official build) (64-bit).
popping
@Bainer55
kselmak
If it's been weeks you better contact moderators to take a look at your account
https://publicmobile.ca.ada.support/chat/
@Bainer55 wrote:
ive tried it on 2 seperate lap tops, and on two seperate iphones. Even cleared the cookies and cache still nothing shows up
@Bainer55 , if you have tried everything possible, I suggest contacting the moderator team for assistance.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team.
When I posted I had tried it and I got the same thing. Now after these few minutes it works. Like I said...mood. 🙂
@hairbag1 wrote:
@Staliger wrote:
@Bainer55 The page is blank for me as well. Probably, it is a tech issue and will be resolved itself soon. Or you can create a ticket with SIMON by clicking ? on bottom right.
I just tried it using Firefox / Private Window....was able to change plans if I wanted. Try using a different web browser than whatever you currently have been using.
Staliger
ddeep91
@Bainer55
You are actually right! I can confirm!
The page does come with Blank and the current plan is not listed either.
Could it be bugged?
I would suggest, Opening a ticket with the  Mod team! So they can help you change the plan and also fix the bug.
To Submit a ticket,
Start a conversation with the Public's virtual assistant, SIMon Click The "?" at the bottom right corner.
This connects to the Autobot SImon.
  • Type "Moderator" and follow the prompts.
  • Click on the " Account Specific Question
  • Afterward click on "No, I want a human
  • You will see a "Submit a ticket Click me!
Cheers
Naepalm
I don't think the latter statement is the case. Couple suggestions, try logging in from a different device like. a laptop or another phone. Second, if that doesn't work try clearing any browsing history and cache or cookies. If you still have issues then as SIMon
Stay Safe and have a great day!
geopublic
@Bainer55 Make sure you using the latest version of the browsers. Chrome and Edge work best. Make sure JavaScript is enabled.
Bainer55
 @Bainer55
There's no conspiracy.
Try using a different browser or clearing cache/site cookies or using incognito/private mode.
Although sometimes the site gets in a mood. Try again in another while using the above ideas.
