Cannot text out.
04-15-2021 05:42 PM - edited 01-06-2022 01:48 AM
I just got a Motorola g fast. I can receive texts but I cannot send out texts
Joining Public
04-16-2021 08:33 AM
@Bev2 , try this to reset network
- At first open the Settings.
- Then select System and Advanced.
- After that choose Reset options and Reset Wi-Fi, mobile & Bluetooth.
04-16-2021 07:40 AM
Try this....
If you are using Hangouts as your default messaging app and this is the first time you have trouble sending or receiving SMS or MMS messages, then try to quit the app and then re-launch or open it again
04-16-2021 07:27 AM
Still not working. Thanks for trying!
04-16-2021 04:49 AM - edited 04-16-2021 04:59 AM
@Bev2 wrote:I cannot find reset network settings. Is that the same as erase all data (factory reset)?
No, not the same. Factory reset erases everything including pictures, mesaages, apps, and phone numbers. Network reset puts wifi and network settings back to the start.
04-16-2021 04:44 AM
04-16-2021 03:48 AM
I have the $25. Plan. Unlimited talk and text.
04-15-2021 07:50 PM
@Bev2 wrote:I just got a Motorola g fast. I can receive texts but I cannot send out texts
If you are iphone:
*ensure imessage is enabled
*ensure SMS is enabled
If you just ported a phone number into Public Mobile or just activated with a new number give it another hour or so.
You could also try one or more of the below:
*turn off your phone, leave off for a minutes, then reboot
*removing your SIM for a few minutes, then reinserting it
*go into airplane mode for a few minutes, then going back to regular mode
*reset network settings
04-15-2021 06:17 PM
i suspected the chat features too, but that's Google messaging specific. let us know what specific app you're using for texting and we can go from there. and let us know what you've tried so far (reboot, etc)
04-15-2021 05:46 PM - edited 04-15-2021 05:47 PM
Maybe the Chat feature is turned on?
- On your device, open Messages .
- At the top right, tap More. Settings.
- Tap Chat features.
- Toggle "Enable chat features" on or off.
Does this work?
If still not work, just want to confirm what plan do you currently have?
