04-27-2019 11:26 PM - edited 01-05-2022 04:38 AM
I just renewed my plan after two months. I am receiving the following message when trying to make a local call - same area code and literally the other person is in the same location as me and is also a Public Mobile customer.
" Sorry we cannot complete your call. you don’t have an active long distance add on and this call is not covered by your plan get an add on by dialing *611"
Joining Public
06-28-2019 09:23 AM
@Francesca1 wrote:i can text and receive calls but can't call out. I don't have a data plan
What exact plan are you on?
There are 2 limited-minutes plans. You *might* be on the $15 one where you might have used all your outgoing minutes. Other than the "don't have data plan" wrinkle. Maybe you're just not aware you have a small data bucket to use.
06-28-2019 08:49 AM
If you still have problems then contact a moderator.
Moderator can be reached at
It can take 48-72 hours for a response depending on workload.
06-28-2019 08:48 AM
Try the lost phone trick. Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
06-28-2019 08:44 AM
06-27-2019 06:34 PM - edited 06-27-2019 06:36 PM
@Francesca1Is your account active? Can you use the data on your plan if you have any? or send a text?
06-27-2019 06:16 PM
You can try the same steps as was suggested to the original poster...
1. Login to your self serve account.
2. Click on "Plan and Add-Ons" tab.
3. Click on "Lost/Stolen Phone" tab.
4. Click on "Suspend Service" button.
5. Logout and wait for a few mins.
6. Login again and get back to the "Lost/Stolen Phone" tab.
7. Click on "Resume Service" button.
8. Restart your phone.
Let us know if this gets things right.
06-27-2019 06:11 PM
I have the identical issue and am also in Victoria. It’s really frustrating!!!
04-29-2019 11:05 AM
Thank you! I appreciate all the help eveyone is trying to give me.
04-29-2019 11:02 AM
@Julyfirst - The moderators sometimes monitor this community, but private message is the best way to ontact them - which you have done. Response times can be between a couple of hours and a couple of days, depending on how busy they are. Hang in there, they will hopefully get to you soon.
04-29-2019 10:51 AM
I wrote the moderator team last night- no response. Does anyone know if anyone actually monitors these messages? I am getting desperate- I now have two phones neither is working.
I just sent this addtional message:
"I wrote yesterday with no response. Since last week I cannot make or receive any calls! I am getting a voicemail message as follows when I dial;
Anyone calling me gets a busy signal. This is happening to both my Public Mobile phones (mine and my partners) Her phone was working fine until Saturday past.
We are paying for a service we are not receiving. I contacted the community and tried all their suggestions without success.
We are both located in Victoria British Columbia. The numbers are (hidden) and (hidden)
04-28-2019 06:24 PM
Thanks have contacted them. Hope they respond.
04-28-2019 04:01 PM - edited 04-28-2019 04:08 PM
@Julyfirst wrote:What do I do now? There is no one to call at Public Mobile to help me. Thanks for all the suggestions.
There was a message earlier explaining how to contact Public Mobile. To contact the moderators, please go through this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-28-2019 02:03 PM
I have tried all these suggestions:
Dialed number direct
Dialed number with 1 in front
Self serve reported lost/stolen phone and reactivated
Added $1. to account. Nothing works. I am still getting the same message.
Yes, I recently returned from Mexico but did not use the phone there, I just suspended my service while gone. I was able to use the phone for about a week but I suddenly started to receive the message.
04-28-2019 01:24 AM
@Julyfirst wrote:I just renewed my plan after two months. I am receiving the following message when trying to make a local call - same area code and literally the other person is in the same location as me and is also a Public Mobile customer.
Did you by any chance return from abroad? If yes, it's possible that when calling from your contacts it's adding 011 and before the number. What happens if you call the number directly from your phone app?
04-28-2019 12:32 AM - edited 04-28-2019 12:32 AM
If the lost/stolen or dialing 1 doesn't work, try paying $1 to your account. If that all fails, you need to contact Moderator_Team at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-27-2019 11:31 PM
Try dialing number with 1 in front of phone number.
04-27-2019 11:30 PM
Can you make call to another other number? Is it only this number giving you the problem?
You can try lost/stolen trick as follow and see if it helps:
