04-27-2021 05:28 PM - edited 01-06-2022 01:54 AM
Hello admin,
I just got my public sim and the mobile network is good but my first call is not going through i.e I cannot hear any sound ring and dialing ends after 3min despite having 100min airtime in my account.
04-28-2021 02:51 PM - edited 04-28-2021 02:54 PM
Welcome to public mobile....and to the community!
I'm happy go see you have utilized the community and it's resources (in this case @computergeek541 ) to figure out your issue....unfortunately its your device not being completely compatible with public mobile as calling is done on the 3G network
In the meantime while you decide if you are going to purchase a completely compatible device with public mobile or switch to a higher tier provider ( if you do so make sure your phone is supported by them for voLTE calling or you could run into a similar issue) you can download the fongo app that has free wifi and mobile data calling (0.5mb=1 calling minute/250mb=500 calling min) so you have access to calling albeit with a different but canadian phone number. If you are on the $15 limited outgoing calling plan fongo is great to use to check voicemail so you don't waste outgoing minutes to check your messages.
The community members are always happy to help answer your questions or help solve your issues. Most of the time we can do that unless its a specific account issue. Once we identify that issue then we recommend moderator contact so that we don't waste their valuable time on minor issues and allow them to quickly respond to more urgent issues for customers with problems that we cannot fix..... Most of us try not to jump the gun and tell you to contact the moderators when it is unnecessary but if you do end up needing help from them then and only then does the following information apply as previously supplied above.....
@RosieR wrote:
@Rasaq wrote:Hello admin,
Hi @Rasaq we are just fellow customers here. If you want to talk to a Public Mobile employee, they are called moderators.
Two ways to contact the moderators:
- Preferred way – Click the chat bubble at the bottom right of the page or click this link >> type “talk to human" >> "account-specific question" >> "no, I need a human now" >> Click here to submit a ticket!
- Alternative way – Send a private message to the Moderators_Team here. You have to be logged in to your Community account for the link to work.
It may take from 1 hr to 2 days (faster response these days) to receive a reply from the moderators. Keep an eye on the envelope icon on top right for a number to pop up. That would be the moderator’s reply.
Moderators are available:
- Monday to Sunday: 6 AM to 10 PM EST
Please keep us posted
RosieR
REMINDER: Please do not post any personal information in the forums. These are public forums and there are quite a number of fraudsters lurking around ready to steal your personal info.
04-28-2021 07:05 AM - edited 04-28-2021 07:07 AM
@Rasaq wrote:I use infinix S5 Pro, android version 10. I currently have 2 bars on the network of my phone. I can text and use the internet but cannot receive or make calls. I did a network reset several times but my network state still reads disconnected.
Unfortunately, I suspect that you're going to have to purchase a new phone. From what I see, this device lacks UMTS Band 2. While calls are possible on UMTS band 5, not all locations have that in the area. In such places, you will not be able to make or receive any phone calls. The also suspect that the reason you're able to use internet and text messaging has to do with both of those services being available while being connected to the LTE network. In short, this model isn't good for use in Canada.
04-28-2021 06:51 AM
04-28-2021 06:24 AM - edited 04-28-2021 06:24 AM
@Rasaq wrote:I got the Sim yesterday and I have been able to text and use the internet but still cannot make calls or receive calls with it. I have rebooted the phone countless times and still will not make calls.
Kindly help.
Rasaq.
Have you tried a network setting reset?
What phone do you have?
Are you showing any bars on the top of your phone?
Ensure your Mobile Connection is on auto connect:
04-28-2021 05:38 AM
Kindly help.
Rasaq.
04-27-2021 06:48 PM
@BKNS27 wrote:Try rebooting the phone by powering off wait 10 minute and power up the phone.
Rebooting phone after activation is an important step for the new phones.
For the old phones, the SIM card slot is under the battery. Changing SIM card means the phone will be restarted with remove and reinserting the battery. But nowadays, phone battery are not removable and we can change SIM card without turning off the phone.
04-27-2021 06:28 PM
What do you mean by the "dialing ends after 3 min"? Do you mean the call connects for 3 minutes then drops or the number dials (trying to connect) for 3 minutes without connecting and then drops?
This is likely an activation hurdle where the best cure is simply time for the system to associate with the SIM card in the device.
Wait for 1 hour, reboot device, remove and reinsert SIM card, toggle airplane mode on/off, reset network connections.
If the activation was completed correctly (and you responded "Yes" to the port request if porting from another mobile provider), things will work. If you did port, see this article for information on the process:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
04-27-2021 06:20 PM
04-27-2021 06:07 PM - edited 04-27-2021 08:18 PM
Is this your phone/SIM card/account OR is it the other caller's phone/SIM card/account?
I would try:
IF above does not improve what is happening, it may be an account provisioning issue, only the Moderators can re-provision it.
If the account recently new, it may not have provisioned correctly. Follow methods provided by @RosieR to have Moderators look into your account.
04-27-2021 05:39 PM - edited 04-27-2021 08:19 PM
RosieR
