Cannot get to chat
jRGTdAZrQjHY
Hello there
How can I get to chat with customer support person?
thanks,..Val
slusagm
What exact problem you need help with? Tell us the issue and maybe we can help
But if you need PM to help instead, then open ticket.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:    https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@jRGTdAZrQjHY
PM support is online only and they will communicate with you via private message after you submit a ticket.
If you cannot submit ticket using Chatbot, you will need to open ticket with PM CS_agent by direct message using this link:
But I have escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
Chalupa_Batman
@jRGTdAZrQjHY wrote:
Hello there
thanks,..Val
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
