Cannot connect
02-29-2020 07:00 AM - edited 01-05-2022 09:42 AM
Signed up to Public Mobile and I went into Networks and it says that I am connected but still cannot get service! Help!
Phones
03-06-2020 08:14 AM
If you are having trouble with your services, the next step is to contact a moderator. Here is the link to create a ticket through SIMon:
https://www.publicmobile.ca/en/bc/get-help -> Click on Chat with Simon on the line "ask me something" write "moderator" -> then click on "account specific question" -> afterward click on "no, I want a human" -> finally you will see an answer "submit a ticket Click me!"
03-06-2020 07:42 AM
How do I contact them?
02-29-2020 08:34 PM
@TheresaK Have you messaged the moderators?
02-29-2020 04:22 PM
Updated phone and that didn't work either.
02-29-2020 03:40 PM
Trying this now.
02-29-2020 10:58 AM
@TheresaK wrote:This didn't work either. Oh my!
Are you referring to not being able to use the SIM card in a different phone? If that is the case, it is likely the account set up failed in some way. To address this kind of issue you will need moderator team support. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
02-29-2020 09:47 AM
02-29-2020 09:19 AM
@TheresaK wrote:Yes, it says no network connection.
This could be an account related problem. Can you try the SIM card on a different phone to confirm the account is functional.
02-29-2020 08:40 AM
@TheresaK Check your phone for any software updates. Do you have access to WiFi?
- On the keypad, press OK.
- Scroll and select Settings.
- Scroll to the right under Device.
- Select Device Information.
- Select Update phone.
- Select Update Firmware. If prompted, select a Wi-Fi network.
02-29-2020 08:32 AM
02-29-2020 08:12 AM
@TheresaK What happens when you dial *611 from your phone?
02-29-2020 08:00 AM
@TheresaK If airplane mode doesn't reconnect you then try resetting your network setting:
- From the home screen, Press the Call key.
- Press Dialer.
- Dial ##72786#.
Note: The Final # may not display.
- Press YES. The handset will restart.
- The phone will restart and Hands Free Activation will begin.
02-29-2020 07:39 AM
@TheresaK Try turning airplane mode on. Wait 5 min. Turn off. Try to makes a call.
02-29-2020 07:31 AM
@TheresaK wrote:Yes, I have calling but won't work. The model is Alcatel model 4044V
This model? This phone is compatible on 3G. So you should have no problems with calling. Do you see a signal strength indicator with possibly a 3G symbol on the notification bar? Would it be possible to post a screen cap or two? It doesn't make sense why the phone would indicate a connection but phone call won't work. For data it is a little more involved with making sure the APN settings are correct.
https://ca.alcatelmobile.com/alcatel-go-flip/
02-29-2020 07:26 AM
02-29-2020 07:24 AM
@TheresaK wrote:I have a alcatel phone, model number 4044V. When I go into the setting, then carriers, it shows Public Mobile and it says connected.
Does the notification bar show connection with signal strength indicator?
02-29-2020 07:23 AM
Rebooted my phone several times and still never worked, it just keeps searching but nothing. It shows that I am connected to public mobile when I go into the carriers but still not working.
02-29-2020 07:23 AM
02-29-2020 07:20 AM
No, I picked a number from Public Mobile.
02-29-2020 07:13 AM
02-29-2020 07:10 AM - edited 02-29-2020 07:11 AM
@TheresaK Try rebooting your phone first. Does public mobile appear at the top right of your phone screen? If not go to your network settings and choose public mobile if it appears.
Did you pick a new number or port in your own number?
02-29-2020 07:08 AM
@TheresaK , after activation what does your self serve account look like? Does it show active status with the correct plan loaded in the account? What phone are you using? I am not sure what you mean by checking networks for connection?
