02-09-2021 02:38 PM - edited 01-06-2022 02:04 AM
Been using Samsung S4 FOR SOME TIME,on PM network. Yesterday stop connecting .cannot dial out or receive calls.
How do I fix this ???
Thank You
02-10-2021 04:42 AM
@Padcorp Please keep us updated on the situation and if it was resolved.
02-09-2021 10:13 PM
Possibly simjacked. Check your account and be sure your SIM card matches
02-09-2021 04:04 PM
I believe that it may be your sim card. I would order an extra just to keep for situations like this and can rule out problems quickly. can get them for under 5$ shipped to your door on some sites including amazon.
02-09-2021 02:46 PM - edited 02-09-2021 02:46 PM
If you are a victim of being sim jacked as per @RossN @here is the HDI thread on next steps you need to take.
https://productioncommunity.publicmobile.ca/t5/Announcements/SIM-Swap-Fraud/m-p/650969
02-09-2021 02:42 PM
02-09-2021 02:42 PM - edited 02-09-2021 02:45 PM
@Padcorp wrote:Been using Samsung S4 FOR SOME TIME,on PM network. Yesterday stop connecting .cannot dial out or receive calls.
Thank You
@Padcorp hi if nothing works data text go into your self serve account and check to make sure your sim card number matches with the sim in your phone there have been issues with sim swapping
