7 hours ago
I am having trouble making outgoing calls. is anyone else having this trouble. I need help
6 hours ago
Yes incoming calls ok but not out going calls since 9 am
6 hours ago
Can confirm that in addition to BC and Alberta, I'm having similar issues in Saskatchewan.
7 hours ago
Okay I will submit ticket and thank you
7 hours ago
BC
7 hours ago
yes, many have the problem today. You are from Alberta or BC?
I have make a summary here
https://productioncommunity.publicmobile.ca/t5/Get-Support/Alberta-Voice-problem/m-p/1243328#M858105
I suggest you to open ticket with PM so they know you are affected
open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
7 hours ago
No not new account
7 hours ago
Is it a new account or ported number?
