Cannot call out. Cannot text out.
JK8
I just activated online with a voucher. I can receive calls. I can receive texts. Got a new number.
I cannot make outgoing calls. I cannot send any texts. I have a iPhone 6.
$15 plan. @gpixel I spoke too soon about the problem being fixed.
@JK8 wrote:
@gpixel wrote:
@JK8 try resetting your network settings
1.. From the home screen navigate to Settings>General>Reset
2. Tap Reset Network Settings
If prompted enter your passcode
3. Tap Reset Network Settings
4. Restart your phone
Did this and restarted twice. Now working. Thanks @gpixel
@JK8  Resetting network settings as recommended above will have no effect for calling issues. It appears gpixel4 edited his original reply otherwise I would have not posted my response.
@JK8 power down your device. Remove the sim card wait 5 minutes, reinsert the sim card power up and test.
If it's still a problem submit a ticket to PM by clicking the ? bottom right of your screen.
JK8
gpixel
@JK8
  • try restarting your phone
  • enable/disable airplane mode
  • update your carrier settings
  • turn off your phone remove the sim turn on the phone and reinsert and see what happens
  • check to see if do not disturb is disabled
