04-01-2026 07:04 PM
My account is current. I have not been able to call out from my cell phone all day.
3 weeks ago
Thank you for reaching out. I have rectified the issue. 😁
04-01-2026 07:07 PM
@dixont check
Outage map in your area:
https://istheservicedowncanada.com/
also could be the phone you have if it’s not in the voLTE white list that’s public mobile supports what’s phone you have ?
04-01-2026 07:06 PM
What phone do you have? Are you in Manitoba?
Try Reboot phone and Reset network settings
And check Active Outage
https://www.telus.com/en/ab/outages
