Cancelling
Bdavis_89
Hello, I’m moving to the UK at the end of this month, is there a way to cancel your plan in advance? I’ve read online that you just remove your payment? That seems weird so wanted to see if anyone can advise.
Thanks
and @Bdavis_89 , are you on the new rewards Public Points?
hairbag1
@Bdavis_89
you might wanna message the Customer Support group to remove your credit card info from your file. Then, when your current plan expires...Autopay won't occur and your account will eventually deactivate completely.
@Bdavis_89
since you don't need the service at all, so, just turn off the auto payment option
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscriptionhttps://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
SourDude1234
Hi @Bdavis_89
If you have autopay, disable autopay in your account and just do not pay your bill. It will be automatically cancelled.
@Bdavis_89
yes, you will just need to login My Account to remove the Autopay option.  Login My Account, Profile, Manage Subscription and disable Subscribed there
