Cancel my phone
nicholasmikki63
I need to cancel my phone. I can't seem to be able to log in to do so.
hi @nicholasmikki63 you just need to login  My Account and disable Pre-authorized payments
to get back to My Account , open ticket with CS agent
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
    start by typing : Forgot Login Information
JL9
Out an abundance of caution, even if you have ported out, you can connect with a CSA and ask them to manually remove any payment cards that may have been on your account as every once in awhile the card is still charged due to a glitch, it shouldn't happen and probably won't but this way you cover all of your bases.
will13am
@nicholasmikki63 , what kind of challenges are you having with login?  If you forgot the password, try the password reset.  If you are getting strange errors, try using incognito mode on your browser.
hairbag1
If you've already ported out of PM, then your account is closed and thats why you can't access it.
Account is closed if you've ported.
