Cancel can't use
03-06-2019 08:15 PM - edited 01-05-2022 03:37 AM
This Sim is not compatible with my iPhone 5c. Please refund my plan and cancel
Phones
03-11-2019 08:44 PM
Thank you @Anonymous for your input,
It's always better to check what's going on,maybe even fix it,especially since @Darlene257 mentioned what might be a technical issue.
Let me know Darlene in the end what you'd like to do
All the best,
Cornelia_D
03-11-2019 08:01 PM
@Cornelia_D wrote:Hey there @Darlene257 ,
Let me also be of help with this
@sheytoonhas a good idea, have you tried and see if the phone is unlocked? if you were to put a different sim card in the phone,does it work?
Cornelia_D
Just so you're aware, while the community tries to get the customer to stay around ...according to the Terms of Service, customers can ask you to have their service cancelled.
We all might think that it's unnecessary and suggesting ways to get things working (including yourself) but if that's what the customer wants then that get's into your bailiwick.
@Darlene257: You say the iphone screen says something. What exact message are you seeing on the screen that makes you say that the "iPhone does not support the public mobile carrier"? Phone off, insert SIM, turn on phone...is it giving you any messages? And if so what is/are the exact wording?
03-11-2019 07:36 PM
@sheytoon has a good idea, have you tried and see if the phone is unlocked? if you were to put a different sim card in the phone,does it work?
Cornelia_D
03-11-2019 07:11 PM
@Darlene257, have you confirmed it's actually unlocked? It sounds like it is still locked.
03-07-2019 11:21 AM
@Darlene257 wrote:The screen on my iphone
Ok the moderator are in your case.. so everything will be ok now. You will have the good answer for your problem and they will fix it if it’s in their hands.
03-07-2019 11:16 AM
03-07-2019 09:58 AM
Someone mentioned check phone's compatibility not reliable. interesting, I put my old phone IMEI number, it shows not found, so I did not switch. After I got a new phone, I checked it again, it works.
03-07-2019 09:55 AM
Hello @Darlene257,
We're sorry for the trouble, please send us a private message at https://bit.ly/2CDoc2k, along with your account's information.
Thank you!
03-07-2019 09:51 AM
@Darlene257 wrote:No you are all wring, it says my iPhone does not support the public mobile carrier. Thr phone is unlocked!
Who’s the IT SAYS?
03-07-2019 09:47 AM
03-07-2019 08:06 AM
Seems their iPhone is locked yo a carrier. It sould still work in the 3G network. My mom's iPhone 5C works in PM. They probably didn't realize that their sim card is adjustable. My mom thought the same thing at first time till I helped her out
03-06-2019 10:51 PM
@wickedgx wrote:Public Mobile is a prepaid service. Once you pay, your service starts for the month and there will be no refunds. You can only stop the service by not paying next month (remember to turn off autopay).
You were also suppose to check your phone IMEI before you start to check compatibility
https://www.publicmobile.ca/en/on/get-started
Just as a reminder / clarification: Public Mobile's IMEI checker only reports whether the phone is black listed or not. It is not reliable when it comes to frequency compatibility and has returned many false positives.
While the OP has just disappeared without clarification of their rather vague initial post, unless my quick research is completely off, any model of the iPhone 5C should support at least the 3G frequencies (B2/1900 and B5/850) to make it work with Public Mobile, 4G / LTE compatibility will depend on the exact model.
So, we established that the SIM size can be adjusted and we assume that the phone is not black listed. If we also assume that the OP has the North American version... my guess is on the phone being locked to a carrier outside the Telus/Koodo/Public Mobile family. But there are a lot of assumptions in this already.
For common problems with iOS @CalgaryBen has put together a lot of helpful information and step-to-step instructions in this thread: https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/FYI-iOS-and-APNs/m-p/323118/highlight...
03-06-2019 10:04 PM
03-06-2019 09:04 PM
@Darlene257 I have an iPhone 5S and the SIM card is compatible... but perhaps on your phone when you did put your sim in it it was written not compatible or something like that?? If yes that’s not the same thing and a solution will fix that. Can you tell us which message do you have if it’s your case?
03-06-2019 08:23 PM
@Darlene257 wrote:This Sim is not compatible with my iPhone 5c. Please refund my plan and cancel
All PM SIMs with the exception of early issues are compatible with your iPhone. You need to use the nano SIM which is the smallest piece.
03-06-2019 08:23 PM
03-06-2019 08:19 PM - edited 03-06-2019 08:19 PM
Company policy is no refunds. You can ask moderator to see if they can make exception, but how is the phone not being compatible Public's fault? Is your phone unlocked? If it is unlocked, iPhone 5c should work.
