2 hours ago
I remember that add-ons did not expire, and I haven't purchased add-ons for a while, so just now I purchased a 3GB data add-on without noticing that it had a 30 days expiration.
There is no way I would use 3GB in a month, and I would not have bought it if I had noticed the change.
Is there a way to cancel it?
2 hours ago - last edited 2 hours ago
Hey @David-O
It does state there is a 30 day expire while you purchase it. As long as you haven't used it, reach out to a CS Agent using chat bot bottom right page. I would turn off all data usage to your phone so you don't accidently use any of it until it's resolved. Just know, they will not refund you. If it's approved, they will only credit your account.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
