Cancel Add-on
hmramani
US Data Roaming Add-on(1 GB for 10 days for $20) never worked. Tried to reboot the phone and also tried to update the carrier settings but still unsuccessful. What's procedure to cancel this add-on get refund?
ChuckYeah
The Moderators should be able to see that you were unable to use the add-on as the data would show as unused. I think if you take the right approach, and be kind, they will likely understand. It's not your fault it didn't work.
Dunkman
@hmramani
Are you still in the USA?  Make sure to turn on data roaming for your phone.  Also can try to manual choose the US carrier, either AT&T or T mobile.  Try to switch between carriers.
Here is a good article on US roaming.
https://www.publicmobile.ca/en/on/get-help/articles/us-roaming
Triguy
Add-ons are prepaid so they usually remain in your account until they are used up.  You could  try to contact a moderator to ask for a refund but there are no guarantees.
You will need to send a private message to the Moderator_Team and they will get in touch with you shortly.
