09-14-2019 12:10 PM - edited 01-05-2022 07:05 AM
Hello, I am planning to subscribe to $15 plan that has 100mins Canadawide talk and unlimited incoming. I am in BC - my question is when I travel to other provinces do I buy a roaming add-on or my plan covers calls made and received while I am in another province other than BC? Thanks for your help.
Joining Public
09-17-2019 02:40 PM
Hey guys,
thanks to all of you for clarifying. I appreciate it.
09-14-2019 09:44 PM - edited 09-14-2019 09:44 PM
@Jenvin wrote:Hello, I am planning to subscribe to $15 plan that has 100mins Canadawide talk and unlimited incoming. I am in BC - my question is when I travel to other provinces do I buy a roaming add-on or my plan covers calls made and received while I am in another province other than BC? Thanks for your help.
You don't need roaming add-on in Canada. Travelling is not roaming. Roaming is only when you're in U.S.
09-14-2019 12:42 PM
@JenvinI suggest you buy the 500 minute canada calling addon for $5. this will last untill used and will only be used when your 100 minutes are used up.
09-14-2019 12:16 PM
typically when you travel, in canada, the long distance will be made by people calling you and the calling was canada wide on your plan so you should be covered 😉
09-14-2019 12:15 PM
As @Anonymous says, the coverage is Canada-wide.
For more details: https://www.publicmobile.ca/en/bc/coverage
09-14-2019 12:12 PM
All services work while in Canada.
