12-12-2023 04:50 PM
I had purchased over 5000 minutes for the above add-on. Still my long distance calls are not going through.
12-12-2023 05:56 PM
@sidg To get over 5,000 Canada long distance minutes you must have bought the 500 minute add-on over 10 times. Even adding up all the other minutes add-ons including for other countries only comes to 4,150 minutes. As others have said, can you clarify what you bought and where you are trying to phone?
12-12-2023 05:54 PM
@sidg wrote:I had purchased over 5000 minutes for the above add-on. Still my long distance calls are not going through.
Please tell me that's a typo and you did not actually purchase that many add-ons to get 5000 minutes worth?
I mean, it's fine if that was what you intended, it's just a huge allotment to purchase up-front.
In any case, I presume you're wanting to add long-distance calling from within Canada to another location IN Canada, and that you're probably on the $15 plan with limited outgoing minutes.
Are you dialing the FULL 11-digits number to reach the intended recipient. (i.e. 1-xxx-xxx-xxxx)
Let's start there.
12-12-2023 05:51 PM
What add-on did you purchase?
Only lowest plan requires additional Canada minutes as it it has only 100. All other plans are unlimited Canada.
12-12-2023 05:01 PM
Which addon did you actually buy? And which country are you trying to call?
Even the “300 International Long Distance Minutes $15.00” does not cover all countries, iirc.
12-12-2023 04:53 PM
@sidg did you just purchase this add on ? Did you reboot phone
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
