Canada USA plan
David65
Does the new Canada USA plan mean that calls and texts that originate in the USA are included at not extra charge or do you need an add on?
HALIMACS
Think of it this way @David65
For the purposes of this plan, we have become the 51st state, or another way of looking at it, the 49th parallel is removed.
scary, thought, yes – but only for the purposes of this plan 😉
@David65 yes, for all Canada -US plans , free calls are included. You can call from Canada to US as well as from US to Canada
And data can be used in US just like you are in Canada
dwh1
@David65 @You can call anywhere in the US and Canada from anywhere in the US and Canada with this plan.
Chalupa_Batman
Hey @David65
When you're in the US using this plan, you can call back to Canada at no charge. You can text back to Canada at no charge. You can even use your data down there, once again, no charge.
However, if you're talking about say... Uncle Joe calling you from New York to your number in Canada while you're in Canada, they'd need a calling plan that can call Canada. Thought I'd cover my base on this one too. 🙂
