06-01-2024 09:53 AM
If I have a Canada/US plan for $40.00 per month, do I still need to purchase the data roaming add-on?
2 hours ago
Thanks.
06-01-2024 10:55 AM
HI hairbag
Thank you so much for the information. Much appreciated
06-01-2024 10:27 AM
for those traveling to the US with the Cdn/US plans, make sure you have a volte enabled cellphone that is on the PM whitelist of phones. Without the volte enabled phones, you'll have poor to no talkability in most areas of the US.
clipped from the Help Files...
To check if your device is VoLTE-Roaming enabled, please check this list:
06-01-2024 10:00 AM
Hi Dunkman
Thank you so much. I really appreciate it.
Flyfisherx
06-01-2024 09:54 AM
No, your phone should just work in the USA (talk, text and data). No need to purchase 15 day roaming packages
