09-03-2015 07:12 PM - edited 01-04-2022 12:43 PM
Hello I am an existing Public Mobile customer and was wondering if I can add another phone onto my account. If so how would I do this.
Thanks Tasmom
11-25-2019 08:00 AM
@RoseNash Yes everyone has given you the correct advice...separate SIM, separate account separate email. Same billing address and credit card is fine. Check the announcements in a couple of hours....a referral credit bonus offer is coming out. If you refer your parents with your referral code you will recieve $20 credit and they will recieve $10 + ? Details to be revealed soon....
11-25-2019 07:35 AM - edited 11-25-2019 07:37 AM
@RoseNash Hi you need to have a separate account with a different email you can use same cc if you like
11-25-2019 07:32 AM
I have another sim card but where on my account can I add the second phone with 2nd sim card
04-17-2019 02:14 PM
@acmethod a écrit :Any idea if you can have the same billing info? I'm in the process of converting my inlaws over to public mobile.
Ideally, they would be on the same plan, but creating two could work, as long as they're billed against the same credit card. I'm hoping that's going to work.
It's 1 sim card for 1 account with public mobile. But you can use the same credit card for the 2 accounts.
04-17-2019 02:10 PM
02-29-2016 02:27 PM
02-29-2016 02:22 PM
In this case, will this new account be counted as a referral?
I want to sign up my teenage son for 90-day plan. So, I will order SIM, then create a separate account, and during the account creation process (which will be done by me) I will have to mentioned that it was myself who referred myself? I'm asking because most probably I'll create account for my son under my name.
Would it be better to create account under his name then?
Thanks for answering.
09-03-2015 07:15 PM
NO, you need to order a new SIM card and open a second account with another email address.
Link is https://public-mobile.myshopify.com
You need to create a new "myshopify" account.
