09-04-2015 12:06 PM - edited 01-04-2022 12:43 PM
I am wondering if Public Mobile offers service to their clients when they travel to Europe. And if yes, how much would calls cost?
03-30-2017 06:13 PM
It probably serve as reminder, international roaming is long over due. 😄
03-30-2017 03:28 PM
@xiaolongxie outdated? Well, you ARE replying to a post from 2015 so.....
As for Europe: unfortunately, nothing has changed. PM only offers roaming services for the USA so far.
03-30-2017 03:23 PM
This is SO out dated!
Public Mobile is offering US roaming now.
Just not sure about Europe.
02-03-2017 10:37 AM
Hi @danielsnider,
The accepted norm is to use the term "Global/International Text" for sending text messages from within the carrier's network coverage area, while connected to the home network of your carrier.
The carrier is only able to offer the monthly plans that work while connected to its own network. This is clearly different from international roaming service, which every carrier differentiates.
08-23-2016 05:06 PM - edited 08-23-2016 05:08 PM
OK! Thanks!!
So isn't the "Global Text" feature false advertising then??
08-23-2016 04:58 PM
Hi @danielsnider, nothing has changed in this regard, unfortunately. You will not get any service from Public Mobile outside of Canada. If you're using an unlocked phone (which is likely on PM), you can always pick up a prepaid SIM card and service from a provider in the EU once you arrive.
08-23-2016 03:51 PM
Any change on this? Can you still NOT roam in Europe?
09-04-2015 04:45 PM
Yeah, I hear Roam is a NICE city in Italy as well
09-04-2015 04:42 PM
Yes, it would be nice to see international roaming add-on.
09-04-2015 12:47 PM
That's correct, and I do HOPE, that the LACK of Roaming is ONLY a Temporay Setback, and will ONCE again make a comeback
09-04-2015 12:41 PM
Thanks for the info!
09-04-2015 12:22 PM
Hi, public mobile does not offer roaming service outside of Canada at the moment. So my understanding is that our public mobile phone lines stop working once we step outside Canada.
