Can we re-use a previous email address with Public Mobile to re-activate the service?
06-22-2017 11:04 AM - edited 01-05-2022 02:15 AM
Public mobile keeps the email address as your ID of your account. If you want to re-sign up, you need to use a different email address then you can use the previous one.
Service
06-22-2017 12:13 PM
You can always try logging in with your old email and see what happens or try forgot password. If i temember cirrectly if password doesnt exist it will tell you.
06-22-2017 11:15 AM
With email alias being so convenient, I suggest not taking any chances, just create a new unique ID. The self serve is so fragile, why provide further opportunity for failure.
06-22-2017 11:08 AM
If your old account has been deleted because you ported out your number or failed to pay within 90 days of expiry, I think you should be able to use your old email address.
