Can't view acct details
Kenimura
@CS_Agent
I keep getting the following error when trying to view my account details. Tried logout and log back in, and tried private browsing mode, didn't solve
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page.
I want to know what long distance options I have on my current account.
2 REPLIES 2
passiveegg
I am not sure if you were able to fix your problem, but it seems there is something wrong with your account information. Just message the moderators to help you with that. I had th same problem and they weer able to fix it. Wish you all the best.
will13am
Looks like you've encountered an account related problem. You will need the help of a moderator to resolve this issue. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
