11-08-2022 10:45 PM
Hello,
I've checked my account for data usage and it says 0 MB used but when I turn on my data, I can't browse anything or even download pictures through SMS.
Would appreciate your help.
Thank you.
Service
11-09-2022 11:51 PM
I'll take note of that #. Thanks.
11-09-2022 11:51 PM
Resetting the network settings did the trick. Thanks for all your reply.
11-09-2022 04:18 PM
the website doesn't automatically refresh. you need to press the refresh buttons or call 611 for your current data allotment
11-09-2022 12:25 PM
What is the make and model of your phone?
11-09-2022 09:19 AM - edited 11-09-2022 09:20 AM
Try using different browser. Try Incognito mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to try to log in.
If you tried all above and still see 0GB on your account, most likely you used all your data. Check data usage and sum up all bytes to confirm they are all used up.
11-08-2022 11:11 PM
Which phone do you have?
If you have an LG phone, you need to reset the network settings before data working again on a LG phone after provider change. In addition to network reset, make sure the data is enabled and APN settings is correct on your phone.
11-08-2022 10:56 PM
@lennuj Make sure you have Data turned on from Cellular settings in your phone. Downloading MMS text should work without having any data on your plan. If you are sure Data is turned on, make sure your APN settings are correct.
https://apn-canada.gishan.net/en/apn/public-mobile
11-08-2022 10:52 PM
Log into self service to confirm you have data…..but clear your cache first and go incognito/private mode. Click the spinner icon to refresh the page.
You may also want to reboot, reset network settings or reinstall SIM card.
Ensure your data is on in the phone and your apn settings are correct.
https://www.publicmobile.ca/en/bc/get-help/articles?q=Apn
