Can't send texts
LisaDucharme
Keep getting an Error 2 when sending texts.  Can receive.
Dunkman
@LisaDucharme
What type of texts? Regular texts (SMS)?  or Picture texts (MMS) ?  or both?
Did texting work before?
Is talk and data working?
Maybe try a simple reboot of the phone.
will13am
@LisaDucharme , what phone/messaging app are you using?  Perhaps try clearing messaging app cache and restarting the phone.
@LisaDucharme  Have you tried rebooting the phone ? Do you have sms enabled in phone settings ? You can also try to reset network setting to to se if that helps . If still no luck please
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
