10-16-2017 10:50 PM - edited 01-04-2022 02:46 PM
Hello,
I joined PM about a month ago. It was a bit of a rocky start but for the past few weeks I have been able to use all the features I paid for (send/receive calls, send/receive texts, use data to navigate the web, etc).
Today after my Samsung S6 did a software update I could no longer send text messages. I can still receive them. I checked the APN settings and everything looks fine.
Has anyone else run into this issue? Any advice would be greatly appreciated.
Thanks
11-09-2018 02:26 PM
@mh1983 glad it's sorted out! @Anonymous thanks for pointing mh in the right direction!
11-09-2018 01:39 PM
Z30 is nice! We use one for streaming still and it's a great little device. Love the speakers and rich AMOLED screen.
Re: why MMS, I got annoyed with those popups when switching from SMS to MMS mode. But I see now that there's a way to suppress that notice. I hadn't visited those settings in ages. That, combined with the auto mode to ensure SMS goes through correctly, seems to way to go.
11-09-2018 01:22 PM
11-09-2018 01:18 PM
@Anonymous Bingo! My wife's data was off. Thanks for the hint! And thanks @srlawren too! Appreciate it.
11-09-2018 01:07 PM - edited 11-09-2018 01:08 PM
@mh1983 interesting. That's a new one. I'm not sure what to suggest here. You could definitely reach out to the moderator team via private message (details in this article: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Get-Help/ta-p/251745) to ask them to verify everything on your account configuration but it's odd that it's one contact. It woudln't hurt to rule that side out.
However, I think the more likely issue is one of your phones, something odd with it. I'm a bit rusty on BB10-- @Anonymous have you ever run into an issue like this? Anything you can think of to try? [EDIT: I see you replied while I was tying this--thanks!]
You could try factory resetting your device @mh1983 but that's pretty intrusive and annoying/time consuming process as you have to restore all your apps after and your data from backups (or cloud). Have you tried googling to see if this is a known BB10 issue with workarounds?
11-09-2018 01:06 PM
@mh1983 wrote:@srlawren thanks for the reply!
No platform changes lately. We both use BlackBerry 10 devices (I use a Classic and my wife a Q10). First time we've had any issues with texting between each other.
Maybe it's an MMS thing. Sending MMS needs data to be on. Recieving that MMS needs data to be on. Your BB has a setting to always do MMS. It only gives a check mark as an indication. SMS will give a blue D.
11-09-2018 01:01 PM
11-09-2018 12:08 PM
@mh1983 strange that it's specific to one contact. Did one of you recently switch from an iPhone to an Android device without unregistered from iMessage, maybe? Failing that, what kind of phone are you both using?
11-09-2018 10:31 AM
Specifically, it's one contact that my texts sporadically seem to send or fail to send. Each text has a check mark indicator on the phone so they're going through somewhere. I receive her incoming texts no problem but outgoing is problematic. She's on Koodo.
For other contacts, send/receive works fine.
11-09-2018 08:00 AM
Sorry to bump an old thread but I'm seeing this issue on my phone now: I can receive but I can't send. Is the SMS reset procedure still a valid fix?
03-28-2018 07:19 PM
how do i text southkorea? i tried +82 10 *&*&*&*^%%
10-17-2017 09:58 PM
You might have to send a message to one of the moderators and ask them to reset your SMS from your sim, that helped me when I switched my phones from and android to an apple device.
10-17-2017 02:33 PM
@hlkidd wrote:Mary the moderator was able to sort this issue out. She needed to reset the SMS number on her end which fixed the issue. Yay!
hmm, never heard of this before. interesting.
10-17-2017 11:38 AM
@hlkidd click the link @Mary_M provided above, provide them your phone number, and ask them to push your SMSC to your phone over the air.
10-17-2017 11:37 AM
10-17-2017 11:08 AM
I unfortunately can't get to the SMSC setting - it is greyed out so I can't check to see if it is correct.
10-17-2017 09:00 AM
Hey @hlkidd,
Let us know if you need any help - simply send us a private message! 🙂
Cheers,
Mary
10-17-2017 12:52 AM - edited 10-17-2017 12:56 AM
There's no need to try to make any changes or otherwise double-check your APN settings. APN settings are unrelated to text messaging. Check to see if your SMSC setting has been mistakenly changed as a result of the software update.
10-17-2017 12:00 AM
@hlkidd, these carrier phones are not the most friendly when used outside of the supplying carriers network. There are so many ways your user experience can be sullied. I digress. Is there some sort of network reset feature on this phone. If there is, you can give that a try. Sending sms only requires the SIM to register on the network which I assume is successful given that calling works. Although it is extremely doubtful that the problem is account related, but you could give the moderator team a shout and have them look for any abnormalities with the account. The moderator team can be reached via private message using this link. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
10-16-2017 11:28 PM
Thanks wetcoaster, wet I have rebooted a number of times and I have tried third party messaging apps with no success 😞
10-16-2017 11:00 PM
Are you using the stock messaging app? I assume you did a reboot after noticing the problem?
Some people have had success when switching to a third party app like Android Messages, Textra etc.
Good luck!
