07-12-2023
02:13 PM
07-13-2023
01:21 AM
computergeek541
I can only send pictures in text messages when I'm on data and not on wifi or no wifi network?
07-12-2023 02:17 PM
I see, thanks!
07-12-2023 02:17 PM
@EggYolk wrote:Hi, I am using an iPhone. I find I can send pictures to other iPhones, but not to Android users unless I'm on data
MMS uses unmetered mobile data. Generally you need to have mobile data enabled to send MMS. As for iMessages, that is an iOS platform. Android users would not be able to receive or send iMessages.
07-12-2023 02:16 PM
@EggYolk Yes because of iMessage wanted data to send turn off iMessage and send sms that should work without data
07-12-2023 02:16 PM
That's correct. MMS text messages need to have cell data on. If you have an iphone then you should be able to send to other iphones using wifi or cell data. But that's not real MMS.
07-12-2023 02:15 PM
07-12-2023 02:14 PM
@EggYolk Are you using iPhone ? And out of data . Turn off iMessage and send sms instead see if that helps
