5 hours ago
Recently did a factory reset on my phone (OnePlus 11) because the OS wouldn't update. Doing that seemed to allow my phone to update, but now I am back to my original issue of unable to send photo via text. I updated the access point thing and such as before (see screenshot) and it is still not working.
Sigh, so what is happening now that is stopping me?
4 hours ago
@DC7 For OnePlus phones the SP.MB.COM needs to be in all caps.
5 hours ago
did you try Reset All Networks? I read soemthing it said you might have to do it couple times and not just once
5 hours ago
With OnePlus, there might be a bit more work than simply updating. Many confirmed that you need to delete the current APN profile first. Then Add new profile and add according to this, please note case-sensitive and do not add extra spaces. Remember to save the new APN and then reboot the phone before you try
(and remember, cap or non cap could be a killer, too)
APN: sp.mb.com
(or try all upper case SP.MB.COM)
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
