04-28-2019 05:54 PM - edited 01-05-2022 04:39 AM
Hey everyone, first time posting here 😃
I'm currently having a problem with my phone, Since about 11am ET time Saturday, I haven't been able to send or receive text messages. This is what I have done so far:
- Restarted phone
- Tried other SMS apps
- Took sim card out with phone powered off, waited a minute and restarted
- Verified APN settings
- Factory Reset phone (silly me, now I can't get into my 2-factor accounts that text codes lol)
- Took SIM card out and put in another phone, same problee while my phone recieved texts with my friends SIM card was in it.
Any other suggestions for me? Thanks!
04-28-2019 07:42 PM
@geopublic wrote:
@hycm53 wrote:
@Ryanoneill91 wrote:Hey everyone, first time posting here 😃
- Restarted phone
What's your plan? Is $10 plan that only 50 texts outgoing that you have? if it is that you probably use up outgoing texts.
The only thing you did not try is the Lost/Stolen trick. Might be worthwhile since it acts like a soft account reset
ohhhh I didn't know this trick, I will try this and see!
Unfortunatly this did not fix it =(
@Ryanoneill91 I think you did all you can do from your end The moderators should be able to troubleshoot it and provide the fix.
04-28-2019 07:03 PM
@Ryanoneill91 you can already write a private message to the moderator..here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 they will check in your account. Give them details of your problem. Waiting time is up to 48 hours.
04-28-2019 07:01 PM
- Restarted phone
04-28-2019 06:42 PM
- Restarted phone
04-28-2019 06:32 PM
@Ryanoneill91 wrote:My data works fine, and I can make calls, and recieve incoming calls.
Which phone do you have? Something with the settings..???
04-28-2019 06:31 PM
04-28-2019 06:29 PM
@Ryanoneill91 wrote:I have the $50 8.5gb unlimited text plan. I'm quite stumped
Is your self-serve account shows ACTIVE? Can you call?
04-28-2019 06:28 PM
- Restarted phone
The only thing you did not try is the Lost/Stolen trick. Might be worthwhile since it acts like a soft account reset ![]()
04-28-2019 06:28 PM
04-28-2019 06:25 PM
- Restarted phone
That would not explain why they cannot receive texts though since it's unlimited incoming
04-28-2019 06:02 PM
- Restarted phone
04-28-2019 06:00 PM
- Restarted phone
What's your plan?
