10-12-2023 11:15 AM - last edited on 10-12-2023 02:54 PM by computergeek541
Received my sim card after 10 days. I've been trying to activate it and instead I'm being kicked out of my account everytime I'm trying to proceed making me unable to proceed. Can't contact support since it does the exact same thing, can't call 611 since no SIM card is activated. And that cycle never ends. Would really need some help
10-12-2023 12:45 PM - edited 10-12-2023 12:46 PM
No it doesn’t matter, you can activate the SIM on the app first if you are picking a new number without the SIM in your phone.
If you are porting your old number over to PM, leave the old SIM in the phone and reply to the text from your old carrier with YES.
10-12-2023 12:10 PM
Does tge app need to be installed on the device containing the SIM card?
10-12-2023 11:27 AM
What is the make and model of your phone?
You either have an older phone or you didn’t update the iOS/OS on the phone.
Another option is to have a friend or family with a newer phone download the PM app and activate the SIM for you. Once activated, have them delete the app and now you can manage your account online on your computer.
10-12-2023 11:25 AM
If your phone thinks it's in a different region then you could get a friend to install the app and finish the sign up and then they can remove the app. You don't need to put your sim into that phone.
10-12-2023 11:20 AM
I couldn't dowload the app, so it was done on the website. Give me a moment please.
10-12-2023 11:18 AM
@Helpmepleas Are you using the Public Mobile app? It's a requirement for activation. If that's what you are using then contact customer service by private message here and monitor your community private message inbox for a reply
10-12-2023 11:18 AM
Are you doing this part now in the app (in case you started out on the web page)?
