04-02-2023 02:25 PM
i can’t renew my plan with a voucher , I can’t receive calls or call out not even to *611! What is going on how do I fix this problem
04-02-2023 02:54 PM
Worst case, @marie_peterson , ask Support to do this for you since they're making it difficult to carry on what should be simple self-serve functions.
Public Mobile needs to get this in order given the non-live support this provider offers.
04-02-2023 02:49 PM
there's been "issues" with the 611 system all week. Sounds like should be fixed soon. If you're not in a hurry...try again tomorrow.
https://productioncommunity.publicmobile.ca/t5/Announcements/Update-Ongoing-Issue-611/td-p/963252
04-02-2023 02:30 PM
@marie_peterson try calling 1.855.4PUBLIC from another phone , that works like *611
if that does not work, login My Account to load
