Can't reciecve calls
faheemz
2 REPLIES 2
popping
@faheemz
If you just port your number to PM, you need to wait until your port to finish.
FYI:
Number porting is a 2 stage process:
Stage 1. PM set up your old number on your PM account. Login to your account. Select the [Plan and Add-Ons] tab. Is your old number showing on the [Plan and Add-Ons] display?
If yes, PM has done its work to setup your old number for you to call out, send text and data.
If no, you should send a private message to moderator to investigate. Moderator wait time is 2 - 3 days.
Stage 2. Now, you are waiting for your old provider to release you number to PM. Not until your old provider release your number, all the incoming calls and texts will continue to go to your old provider.  If your old SIM card is still working.  Continue to use your old SIM until it stop working.  Then, start using your PM SIM card.
dabr
@faheemz   Can you provide a few more details?
You can also restart your phone and see if it helps.
