Can’t receive texts from non iPhone users
PamMunc
I recently just got public mobile and I can’t receive texts from non iPhone users My number was transferred over
2 REPLIES 2
@PamMunc if you can receive incoming calls, then this is an iPhone setup issue and not something PM support can help, so opening ticket with them won't get you a solution
First, you need need make sure you can receive incoming calls , try calling yourself from landline and different mobile providers
if you can receive all incoming calls, then Make Sure MMS and GroupMake Sure MMS and Group Messaging Are Enabled Messaging Are Enabled on your iPhone settings
@PamMunc
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send  a  private message   To CS_Agents
