Can't receive text
12-02-2018 02:41 PM - edited 01-05-2022 02:40 AM
12-04-2018 06:09 AM
It fixed its self. Still don't know why it did that when my plan is $50 unlimited talk 8GB data. Never done that before.
12-03-2018 09:49 PM
If your on the $10 plan, it may be because you used up all of your 50 outgoing texts but you would still receive incoming texts.
12-03-2018 06:44 AM
Update: text issue seemed to resolve it's self. That leads me to believe that it may of been a network issue. What ever it was I'm glad it works.
12-02-2018 08:12 PM
The issue isn't with my phone. I put sim in my old QUE 4.5 and still nothing. Hopefully mods can fix.
12-02-2018 05:51 PM
Thankyou messaged them directly,
thanks so much!
12-02-2018 05:16 PM
@tehowennathe wrote:SMSC?
From the link I posted for you.
12-02-2018 05:15 PM
SMSC?
12-02-2018 05:04 PM
@tehowennathe wrote:I contacted a Member of the mod team
Good. Did you try the SMSC thing?
12-02-2018 05:03 PM
12-02-2018 05:01 PM
@tehowennathe wrote:I did a factory reset and it did nothing. I tried using FB messenger and text never come in.
This worked for somebody a couple days ago but not for someone earlier today.
12-02-2018 04:55 PM
12-02-2018 04:04 PM
@wetcoaster wrote:
@MartinB wrote:Hey can someone tell me a moderator that is working today and tag them?? I accidentally did a data only plan, and I was looking to add voice and text 3gb as it is the same price...
hopefully they can rectify my mistake
Always better to start your own topic.
You need to send a private message to the moderator_team.
Yes. In forum-speak it's called thread-jacking. If you were adding on with your own same problem then sorta fine though not really. But not a whole different problem. It's a forum etiquette thing.
12-02-2018 04:00 PM - edited 12-02-2018 04:02 PM
Please be aware that they are working on a first come, first serve basis, and will get back to you as soon a they can.
Use this link to send a private message to the @Moderator_Team, include all relevant information in your message, such as account number, phone number, detailed problem description.
More information on contacting the mods: https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
12-02-2018 03:57 PM
12-02-2018 03:47 PM
Try using a different SMS app.
12-02-2018 03:18 PM - edited 12-02-2018 03:19 PM
@tehowennathe wrote:I have a Samsung Galaxy J5 and using Samsung messeges. One person using iphone 6 and iMessenger. Other is a Galaxy S8 using Textnow. Lost stolen did nothing
The lost/stolen trick is worth a try.
I am running out of idea. Backup your phone and do a factory reset. It is up to you whether you want to try or not.
Note: Before doing factory reset, test your PM SIM card with your friend's phone.
12-02-2018 03:15 PM
I tried switching sim card slots as my phone is dual sim. That didn't do anything.
12-02-2018 03:08 PM
12-02-2018 03:00 PM - edited 12-02-2018 03:05 PM
You don't mention what phone you and the senders are using...
I have no experience with the different layers of iMessage.
If you are on Android you could give a different texting app like Google's Messages a try.
Some people like Textra, but be sure that you are ok with their privacy policy.
12-02-2018 02:59 PM
Ok I am trying it. Will update you once done
12-02-2018 02:55 PM
you could always try the Lost/Stolen remedy. Click on My Account, Add-ons and click Lost/Stolen. Report lost and log out. In a few minutes log back in and report found. Good luck. Let us know if it works.
12-02-2018 02:54 PM
@tehowennathe wrote:I have unlimited text. Data is turned on and works fine. I removed sim card and put back in. I can get calls. Family members get my text but I don't get theirs.
Try the lost/stolen phone trick to re-provision your plan features again. Goold luck.
1. Login to your self-serve account.
2. Report your phone lost/stolen using [Plan and Add-Ons] --> [Lost/Stolen Phone]
3. Logoff
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to provision your account again. i.e. enable all features of you plan again.
12-02-2018 02:50 PM
12-02-2018 02:46 PM - edited 12-02-2018 02:48 PM
@tehowennathe wrote:I am having issues with my text. I can send them and people get them. When they answer I don't get anything. They call me an hour later asking why I never answred text. How do I fix issue?
Hey how you doing. Have you turned on mobile data in setting on your phone?
Your account is active and you have not used up all your text if you are on the $10 plan. Happened to me. Good Luck Lemew
12-02-2018 02:45 PM
What kinda plan do you have ? Do you have a limited amount of texts ?
